Browse Forums Bathrooms and Laundry 1 Oct 02, 2014 5:56 pm I am of the impression that wall tiles are more glossy that low gloss floor tiles and therefore are meant to be on the walls in the bathroom. However, staff from the tile company encouraged me to choose floor tiles for shower wall. citing compatibility in colour. I'm now pretty confused. Could someone please shed some light on this? I prefer functionality over aesthetics. Thanks. Re: Floor tiles on bathroom walls 3Oct 21, 2014 11:05 am Hi Wally Both wall tile and floor tiles can come in both a satin or gloss finish. But a wall tile is generally a less dense biscuit and is used walls only. Also there are factors in the difference in glazing but no need to go into that here. Yes you can use the floor tiles in the shower walls without a drama. Just make sure they are not heavily textured as this makes them a nightmare to clean - for both wall and floor. Do note that even though the batch in colour may be the same for the wall and floor (as you are using the same tile) you will find the wall being a touch darker as it gets a different light source. Cheers Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6066 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8423 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11258 |
