Browse Forums Bathrooms and Laundry 1 Sep 23, 2014 4:11 pm I'm new here Just wondered if anyone had used Smartex connectors as a permanent solution for plumbing repairs/replacements? I am wanting to shut off some water pipes that were installed for an unused laundry sink and tile over the top and also for moving our shower water flow so the shower head is on the adjacent wall. Thanks yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3238 |
