Browse Forums Bathrooms and Laundry 1 Sep 15, 2014 9:16 pm Hi, The design we have sketched to use for our new bathroom has the glass shower door crossing over the same path as the bathroom entrance door - just wondering if there are any building regulations that may prevent this? Obviously the doors would not be opened at the same time. I've attached a very rough sketch. We are in NSW in case that makes a difference. http://s42.photobucket.com/user/AlleyCa ... 7.jpg.html Thanks in advance. Re: Bathroom door and shower door 2Sep 16, 2014 9:12 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ When you go to your photobucket page scroll down to where it says "Share Links" on the right of the photo then scroll down further to "IMG" and click in that box [URL=http etc which will then turn yellow and say "copied". Paste that back into this thread here and the pic will appear. Stewie Re: Bathroom door and shower door 3Sep 16, 2014 10:28 am There is no law that they can not cross paths. Most shower doors always seem to come into contact with main doors. The only way to avoid this is to use a sliding cavity door which are not good. Chances of both of them opened at same time would be rare. I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 9752 I was in a similar situation needing to attach hangers to a hollow bathroom door. I just bought the stick on type with a larger surface area base and used good double… 2 5445 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 13950 |
