Browse Forums Bathrooms and Laundry 1 Jul 03, 2014 12:38 pm Hi, Would you please help or give advice on this: i gotta fix the leaking faucet for the bath tub in my bathroom - but the cartridge got stuck and even i did use the WD40 but it does not get loosen at all! Also what would be the best tool to remove this? I used the socket faucet wrench like below one - but it does not help much (as the handle is too short and so i could not use enough power to twist the thing off) tool i used http://www.keyhole.com.tw/tools/faucet- ... _030_logo/ the stubborn cartridge https://www.dropbox.com/s/n4kn08lb05645b4/1.jpg pls help me! Thanks a lot Regards, Huy Re: stubborn bathtube/shower cartridge!!! 4Jul 04, 2014 1:59 pm Failing that, a 26mm mechanics ring spanner should shift it. That's what I have used in the past for a few but that depends on the brand of your taps and what size the manufacturers used for the tap body. Stewie Re: stubborn bathtube/shower cartridge!!! 6Jul 07, 2014 9:20 am As Stewie mentioned, try putting a longer tube over the short bar that's supplied with the kit, the longer the handle, the more torque you can apply to crack it open. Try & find a strong peice of tubing around the house, to slide over the bar Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9563 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5834 Ask yourself if the insurance company will be aware of the Reno. 4 7370 |
