Browse Forums Bathrooms and Laundry 1 Jun 16, 2014 4:09 pm Hi, I've come across a problem where by we've decided on Australian made tiles for the wall and Italian tiles for the floor. The Italian tiles are Atlas Concorde Glow Planet which are 595x296mm. Obviously the Australian tiles are almost perfectly 600x300mm so I want to get these cut down to match in length, the width can be made up in the grouting. I had a quote of $20 per sq/m for cutting them to the right length, but that seems extortionate, does anyone know any places where I can get some other quotes directly? Cheers Alex Re: Bulk tile cutting services? 2Jun 16, 2014 4:24 pm I would be getting one tile cut so you can see what the cut edge looks like. You may not like it. Or look at staggering the joints by half a tile or laying the floor tiles at 45 degrees Re: Bulk tile cutting services? 3Jun 16, 2014 4:48 pm The cuts would be exactly the same as when you buy them, most 600x300 tiles are 600x600 tiles cut in half. That aside, I would like some assurance that they are cut properly just in case it's some guy and a manual tile cutter Re: Bulk tile cutting services? 4Jun 16, 2014 7:20 pm alexf40 The cuts would be exactly the same as when you buy them, most 600x300 tiles are 600x600 tiles cut in half. That aside, I would like some assurance that they are cut properly just in case it's some guy and a manual tile cutter Um ok A lot of the larger format tiles when cut can leave a jaggered edge when cut. Beetaloo actually has a some good ideas there! Most 600x300 tiles are not 600x600 tiles cut in half!! Granted there are a few but not that many!! You only need to look at the edges and you can tell easily! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 3944 2 7743 Please read your contract regarding handover process. Generally, once final payment invoice is issued you have 7 days to meet builder on site and present a list of… 3 1278 |
