Browse Forums Bathrooms and Laundry 1 Jun 02, 2014 9:55 pm Hi - Just wondering if anyone has some pics of a walk in shower where the shower wet area is raised from the bathroom floor. What I am thinking of is tiling the main bathroom area flat (ie. no bedding) and running 40mm - 50mm angle wall to wall and bedding / tiling the fall flush from the top of the angle rather than running a Hebal hob wall to wall. Does that make sense ?? I was hoping for some pics to send to the tiler to explain what I want quoted ! Re: Pics needed of a walk in shower 2Jun 02, 2014 11:18 pm Sorry I don't understand but is this pic something like you're after? http://i1055.photobucket.com/albums/s507/grumblebum54/majestic-bath2_zpsa5f8bb19.jpg Regards, Grumbles Re: Pics needed of a walk in shower 3Jun 02, 2014 11:23 pm Yeah - so basically, instead of a Hebal hob that you have to step over I am wondering if you can just use a length of angle aluminum to build up the wet area by about 40 - 50mm so I can get fall to the waste. Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 1057 most towels and sheets will fit easily on 300mm deep shelves and my suggestion allows for a counter surface under the window (about 90cm off the floor would be a… 1 2210 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 6190 |
