Browse Forums Bathrooms and Laundry 1 May 18, 2014 8:38 pm This rail has come loose from the wall but not loose enough to work right out, so I need to figure out how it went on. It looks like the chrome bit sits on a brass mounting that is screwed to the wall. But I can't figure out how to get the chrome fitting away from the brass mounting plate. Does anyone know how these work? cheers, Bill Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How to I take off this towel rail. 2May 18, 2014 10:35 pm On the bottom there's a hole that will ave a small grub screw in it, it's either a small flat screw or an Alan key. Loosen that enough and the chrome end will come away from the brass back plate. Re: How to I take off this towel rail. 3May 18, 2014 11:33 pm Thank you. Whoever put it on made a mess of the grub screw so I didn't recognise it for what it was. Problem solved. Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3854 Please suggest a solid quality swivel bar towel holder in bathrooms & bedrooms from… 0 3130 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20434 |
