Browse Forums Bathrooms and Laundry Re: Raised floor in bathroom 13Jan 21, 2015 7:23 pm Custom build Northern NSW viewtopic.php?f=31&t=72217 Re: Raised floor in bathroom 16Jan 22, 2015 8:19 pm Custom build Northern NSW viewtopic.php?f=31&t=72217 Re: Raised floor in bathroom 18Feb 08, 2015 9:54 pm The builder we were originally going with outright said no they would not consider it (pretty common project builder). We changed to another project builder and was easy to arrange. They are doing this in both bathrooms and the laundry and will charge us $750 all up so was happy with that. They determined the flooring height (slab) based on the measurements of the flooring that we are installing. Can't believe how cheap some builders are! Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8382 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11206 Have had a few issues with out recently done bathroom floor. Probably around 18 months old First there has been been a crack running through a grout line which I put… 0 860 |
