Browse Forums Bathrooms and Laundry Re: Removing wall tiles 2Sep 17, 2018 10:18 pm I have never managed to avoid damage to the plasterboard. It's been a case of at best doing a plaster skim of the plasterboard and at worst replacing an area. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Removing wall tiles 3Sep 18, 2018 6:49 am mmdeen How can I safely remove these wall tiles without damaging the plasterboard? As bashworth has said, it’s very hard. Is it plasterboard/Gyprock/drywall or blue board/Villaboard/fibre cement sheeting? Plasterboard will be the most difficult. Your best chance is to carefully cut the tiles into strips with a diamond blade on an angle grinder and then gently chiselling behind each piece. The adhesive will have adhered to the paper over the plaster, so you are trying to sacrifice that and hope that you don’t take chunks of plaster along with the paper. The best advice is for you to get a competent building consultant to guide you through your build 7 4982 thanks, yes they are dry , thats a good idea with fish oil as sanding will be hard 4 3355 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4869 |
