My hot water system is bit old and it is pressure is very low comparing to the cold water.
So normal mixer won't work.
I really don't want to replace the hot water system at the moment due to my budget
Any suggesions, guys?
Thanks
Browse Forums Bathrooms and Laundry 1 May 09, 2014 2:39 pm My hot water system is bit old and it is pressure is very low comparing to the cold water. So normal mixer won't work. I really don't want to replace the hot water system at the moment due to my budget Any suggesions, guys? Thanks Re: unequal pressure when installing a sink mixer 2May 09, 2014 10:20 pm Hot water pressure is generally determined by the cold water pressure going into the hot water. Make sure the cold water connection to the HWS is fully open. As for a solution turn the mixer lever towards the hot water, you'll get less flow but at least hot/warm water. First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 16850 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6695 |
