Browse Forums Bathrooms and Laundry Re: Help needed 2May 06, 2014 12:25 pm I imagine you have a spout thats not a perfect circle where it meets the wall so the scratches are visible once its installed. We had the same problem and the only solution we came up with was to use a rubber washer, which left a small gap that we filled with white silicon to match the tiles. Worked fine and never leaked in the 6 years we were there. http://camdenbuild.blogspot.com.au/ by invite only please pm me Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6882 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 6994 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4084 |
