Browse Forums Bathrooms and Laundry Re: Brisbane bathroom......in need of help :) 10Apr 15, 2014 8:07 am Quote: We do have some obvious leaking signs, with damage happening to the surrounding walls.....this has been going on for many years.... If this is happening then you need to rectify it sooner than later or the damage outside the bathroom could progressively get worse. Personally if you can't afford a total bathroom reno I wouldn't re-do the shower as I think that once you strip it out you will find rotten studs and bottom plate that need to be re-built as well. That will just lead to more work and possibly having to trash the whole bathroom once you start. I'd get some sort of sealer and coat the entire shower area for a temporary fix ( read 6 month to a year ) then do the whole bathroom in one go. Doing a lot of the work like demolition and rubbish removal yourself will save you a lot of cash. Stewie Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10380 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8233 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11258 |
