Hi guys,
I would like to add heated towel rails after handover rather than the builder install them & charge a ransom !
Is it possible? And if yes, how does the builder's electrician do it?
Am I being unreasonable?
Browse Forums Bathrooms and Laundry 1 May 17, 2008 5:00 pm Hi guys,
I would like to add heated towel rails after handover rather than the builder install them & charge a ransom ! Is it possible? And if yes, how does the builder's electrician do it? Am I being unreasonable? Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: HEATED TOWEL RAILS 2May 17, 2008 5:58 pm Southies, I think it depends if you want the hard wired ones or the ones that will plug into a power point?
If it's the first option then maybe run an extra set of wires but not connect them to mains so when you get the electrician in, they can hard wire it to the power cable in the wall and connect it to live power at the other end which will probably be in the roof cavity? If it's the latter, then just add a power point where you need it. Shouldn't be too difficult either way i would think. Re: HEATED TOWEL RAILS 4May 25, 2008 1:32 pm Hi Southies,
We have hydronic towel rails and they are great nice toastie towels!! They run off a switch where the light is and we can leave them on premanently - except when we go away of course Paula Re: HEATED TOWEL RAILS 5May 25, 2008 2:02 pm Paula Hi Southies, We have hydronic towel rails and they are great nice toastie towels!! They run off a switch where the light is and we can leave them on premanently - except when we go away of course Hey Paula - you're back ! Everyone's missed your posts ! What do you mean"they run off a switch where the light is.."? Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: HEATED TOWEL RAILS 6May 25, 2008 3:36 pm Southies Hey Paula - you're back ! Everyone's missed your posts ! What do you mean"they run off a switch where the light is.."? Thanks I mean the switch is on the same thingymibob as the light - one for the light one for the fan one for the towel rail etc.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Paula Re: HEATED TOWEL RAILS 9May 25, 2008 5:04 pm Paula and we can leave them on premanently - except when we go away of course errr...what happens if you forget? mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: HEATED TOWEL RAILS 11May 25, 2008 6:29 pm Paula to_do_list Paula and we can leave them on premanently - except when we go away of course errr...what happens if you forget? Very crispy towels ... I hope that's all.... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: HEATED TOWEL RAILS 12May 29, 2008 4:45 pm The other thing you need to do is add extra noggins in the wall to support it - so if you're going to do it aftr handovr you will need to get in before the plaster is hung and put them in. Re: HEATED TOWEL RAILS 13May 29, 2008 5:02 pm petal The other thing you need to do is add extra noggins in the wall to support it - so if you're going to do it aftr handovr you will need to get in before the plaster is hung and put them in. Oh, didn't realise . Good point Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: HEATED TOWEL RAILS 14Jun 05, 2008 1:20 pm we have ours on, i think one side is on a stud the other is in the cement sheeting with plugs, it has two screws in each corner so 8 holding it up, it aint moving any time in a hurry.
Ohh and i agree atleast get it prewired .. we had ours prewired to the automated lighting, turns on between 8:30 and 10:30 if we are home so its warm at night time, doesnt turn on if we are out (alarm) and can over ride with one of the light buttons by the bathroom door. The auto is awsome, if you are running standard 240v wiring why not have a timer in say the shaving cabinet and an override on switch near the doorway. Re: HEATED TOWEL RAILS 18Jun 12, 2008 11:32 am Hi all, I have heard that heated towel rails use a lot of power and therefore boost your power bill, is this right?
How yummy to have warm towels after a shower . At the mo I stick the towel over the ducted heating vent to warm it up before I go in but it's not quite the same Re: HEATED TOWEL RAILS 19Jun 12, 2008 4:36 pm Kingy Hi all, I have heard that heated towel rails use a lot of power and therefore boost your power bill, is this right? How yummy to have warm towels after a shower . At the mo I stick the towel over the ducted heating vent to warm it up before I go in but it's not quite the same Yes, they use a lot of power. So you don't want them on all the time. Ideally you want about an hour after the wet towel goes on (to get them dry) and an hour in winter before you use them. Using a timer will give you a warm towel on a cold winters morning and keep your power costs reasonable. Demolition August 2009, Construction Started September 2009, Completed December 2010 Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3852 Please suggest a solid quality swivel bar towel holder in bathrooms & bedrooms from… 0 3130 |
