Browse Forums Bathrooms and Laundry Re: Help needed to remove the tap head 2Dec 03, 2013 8:12 am Pics??? You need to help us to help you! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 6174 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 14387 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 4025 |
