Browse Forums Bathrooms and Laundry 1 Aug 20, 2013 10:48 pm Hello, After preliminary council approval we reached the stage of creating final plans for our extension. In one part we will have a new 4x5 master bedroom with a built-in wardrobe and a new ensuite. We have a fixed rectangular area of 3.68m x 2.47m for a wardrobe + ensuite. It can not be increased due to council regulations on required boundary clearances. So the ensuite has to be of the L-shape as shown below. I would like to put there a shower, double vanity and bath and leave a reasonable space for the wardrobe. So I would appreciate any ideas on design improvements. Thank you. http://img838.imageshack.us/img838/2162/3tjg.jpg Re: Help with ensuite design 2Aug 20, 2013 11:46 pm Have you considered a cavity-sliding door for the ensuite. That would allow you to move the vanity closer to the doorway. For a high-end look you could put a wooden-framed door with a glass opaque panel. If you make that change, you could put a free-standing bath where the shower is. There just needs to be enough room for getting around it to clean it. You would also need a floor-mount bath spout (you can get these with a hand shower as well). You could have a shower where your plan shows the bath. Consider a frameless (doorless) showerscreen in that spot. That is quite popular. Other threads on this site suggest googling for "small bathroom layout" (look at the image results). Also check out houzz. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Help with ensuite design 3Aug 21, 2013 6:40 am I agree with what maximus has suggested, just make sure there is a decent amount of space between the bath and the back of the WIR. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Help with ensuite design 4Aug 21, 2013 9:08 am reece has a bathroom planner tool, you can use it to shuffle things around quickly. Re: Help with ensuite design 5Aug 21, 2013 12:25 pm Thanks a lot for your replies. Actually I thought about this option, i.e. making a wet shower in the bath spot and moving the bath parallel to the vanity. This option is quite attractive. However, how noisy are sliding doors ? My wife gets up before 6am and goes to work very early. If a sliding door makes a lot of noise, it will create some problems. Of course, one can always use the main bathroom, but this somehow defeats the idea of having a separate ensuite. Also I was thinking to put a free standing cast iron bath there and we could probably go for a shorter option. Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6142 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11836 |
