Browse Forums Bathrooms and Laundry Re: Can PVC piping be used for the out-vent for a dryer? 2Aug 18, 2013 10:33 pm From what I remember the vents on the clothes driers at the hotels I maintained were metal. Same as the ships I look after. Can't recall using plastic vent tubes. Re: Can PVC piping be used for the out-vent for a dryer? 3Aug 19, 2013 8:17 am Unless it is special high temp rated PVC I'd say no. Normal 100mm PVC sewer pipe has a max continuous temp usage of 60ºC which is why metal ducting is preferred. The cost of the special high temp PVC pipe and fittings is probably quite a bit more than what the equivalent metal pipe would be anyway. For reference AS2032 is the AS I've seen quoted for this situation. I don't know how you would go with your insurance company either if your place caught fire because of non-compliant ducting. Stewie yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 857 |
