Browse Forums Bathrooms and Laundry 1 Jul 25, 2013 3:28 pm I was interested in installing a front venting dryer in our home. Unfortunately the model that I was looking at does not have any tubing to direct the expelled/damp air outside. I was wondering if there were any universal adaptor kits or other solutions to this problem (I don’t want to have the laundry filling up with damp air). Re: Tubing for front venting dryer 3Jul 26, 2013 8:44 am I'm pretty sure most front venting dryers are made specifically to vent straight out without a pipe, (other wise you'd have a pipe laying around in the room) Why don't you just get a dryer with a normal rear/side vent and then run your pipe from that? Or as E1109 said, if you have a window or exhaust fan in the room, you can use those with your front venting dryer. Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7394 |
