Browse Forums Bathrooms and Laundry 1 Jul 14, 2013 10:14 am The caulking in the base of my tiled shower keeps coming off where the grout lines meet. I suspect its because there is grout under it so its not sticking as it should cause it gets wet. I've read you should do one or the other but not both which makes sense. Any advice please? Re: Tiled shower base caulking 2Jul 14, 2013 4:42 pm Define keeps coming off... Once a week, month or 5 years..... It shouldnt be a big deal and should be effective as long as the surface and grout is 100% dry. The slightest bit of moisture can cause it not to stick. I have even used a hair dryer in the past to make sure all the moisture was out before re sealing Re: Tiled shower base caulking 3Jul 15, 2013 7:58 pm Along the base of the tiles where the floor meets the wall, where the caulking runs over a grout line, it doesn't stick. It was recently re caulked and it should of been bone dry as we hadn't used it in months. Re: Tiled shower base caulking 5Jul 18, 2013 12:12 am It shouldnt fail that quickly, As JB1 says, what did you clean it with. Clean water is the best bet, then give it a rub with a dry cloth even after it is dry. Im pretty sure the Code states that a flexible sealant should be applied, I dont think it makes mention of using the grout, I would have to check the wording. But either way it shouldnt fail that quickly. If you are beyond belief, there is a silicone that can be applied in the wet, I have used it before, it is very pliable, almost like blu-tac., Made by Selleys. It would be very hard to get a neat bead with though as it doesnt flow like traditional silicones. If you think your technique is flawed, there are people out there that specialise in silicone work. Some cleaners that do builders cleans do, and there is specialied businesses in it believe it or not Andrew I have seen poly marble shower bases last in excess of 30 years 1 3042 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 3610 Thank you so much. We ended going with the terrain that’s part of our brick. 2 1392 |
