Browse Forums Bathrooms and Laundry 1 Apr 29, 2008 11:43 am Hi all,
Just wondering if theres a way to locate copper pipes in a bricked wall. We've discovered that this was one stage of our build we neglected to take pictures of so now that our ensuite is tiled are trying to figure out where the pipes for the shower are in order to install a rail type shower head. Cheers Re: How to locate copper pipes in walls? 2Apr 29, 2008 12:48 pm A good stud finder may pick up the pipes - check with manufacturers etc Re: How to locate copper pipes in walls? 5Apr 29, 2008 7:35 pm royalblue Drill into the wall. If water comes gushing out, you've found it! Glad to help! Ash. I knew it…..I knew as soon as I read the title and saw your name….that’s what you would say! I think I know you too well Ash…..scary! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: How to locate copper pipes in walls? 7Apr 30, 2008 1:48 am Thanks guys for the ...errr pointers After talking to a couple of plumbers about the logical expectation of the pipe work for our layout I proceeded albeit with a slight concern. Hitting a pipe wasn't a situation I wanted to endure and the mrs kinda half expected it seeing as I tend to be the unlucky one. Happy to report all went well.
One discovery though....10mm thick porcelain tiles are certainly a hard material to drill through. 4 holes took me about 2 hours to slowly make it through without damage to tiles....with the towel rails, gown hooks and mirrors to go i estimate another 8 holes to go. EEEK! Re: How to locate copper pipes in walls? 8Apr 30, 2008 1:57 am Go to Bunnings or a tool store and get a glass cutting bit. Looks nothing like a drill. Its a flat spade shaped, pointy bit with a diamond coating on it. Cuts through hard ceramics very easily.
Oh yeah, some smart cookie on this forum said to tape over the area first with masking tape, so you don't slip when starting the hole. Ash. Re: How to locate copper pipes in walls? 9May 02, 2008 10:13 pm Ummm The easiest way to drill holes in the walls.....nobody has thought of this yet.......Let someone else do it.
Glad for your sake you didnt hit any pipes..well done Best Price Wardrobes Sliding door robes | Walk in robes Deco panel | Mirror | Melamine 26 to 28 Cottage lane Hackham M: 0402 927 376 http://www.bestpricewardrobes.com.au Trade welcome Re: How to locate copper pipes in walls? 10May 02, 2008 11:45 pm royalblue Go to Bunnings or a tool store and get a glass cutting bit. Looks nothing like a drill. Its a flat spade shaped, pointy bit with a diamond coating on it. Cuts through hard ceramics very easily. Oh yeah, some smart cookie on this forum said to tape over the area first with masking tape, so you don't slip when starting the hole. Cuts through the tiles like butter, wacked some utensil railing up in the kitchen using this method.....including the tape. The tape also helps you draw fine pencil lines rather than a texta dot or thick texta line. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 5163 4 5135 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5737 |
