Browse Forums Bathrooms and Laundry Re: Shower head/arm replacement 2Jun 17, 2013 3:40 pm Its as easy as taking candy from a baby! Turn the water off. Drain the water by turning on a lower tap(vanity) until the water stops running Using the correct spanner remove the old shower head/arm Wind plumbers tape around the wall screw fitting Fit the new shower arm and head. Turn water back on and check for leaks Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9564 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17530 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7226 |
