Browse Forums Bathrooms and Laundry 1 Jun 03, 2013 9:56 am The toilet waste pipe in our slab should've been positioned at 150mm centre setout from the plaster wall but has ended up only 115mm - 35mm short! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The toilet we bought to use is a close coupled vitreous china so no adjustment it seems. http://www.marbletrend.com.au/products/ ... ilet-suite Are there toilets that will fit the 115mm centre? And, can anyone PLEASE recommend a model? Any advice would be greatly appreciated. Re: Toilet waste too close to wall. Help! 2Jun 03, 2013 11:23 am Pan photos to show the problem. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Will one of these work with the pan? http://www.plastec.com.au/Products/Pan- ... ffset.aspx Although, I'm concerned the pan won't sit flush on the floor. http://www.plastec.com.au/getattachment ... s.pdf.aspx Can I provide any other dimensions to assist? Re: Toilet waste too close to wall. Help! 3Jun 03, 2013 12:08 pm The offset coupler should work perfectly! I installed 3 toilets in my house that were very similar with and offset coupler exactly like that one. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Toilet waste too close to wall. Help! 5Jun 03, 2013 8:59 pm It will work but I have found with the new dual flush toilets these days being very water efficient, being a 40mm offset can cause paper blockages so be ware if you are a person who likes to use 1/2 roll of paper in the morning! Re: Toilet waste too close to wall. Help! 6Jun 04, 2013 7:35 am Plumbergasfitter It will work but I have found with the new dual flush toilets these days being very water efficient, being a 40mm offset can cause paper blockages so be ware if you are a person who likes to use 1/2 roll of paper in the morning! Good to know! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Toilet waste too close to wall. Help! 7Jun 04, 2013 10:37 pm Could you not exchange the toilet for one that is a Back-to-Wall (BTW) type? I note marbletrend seem to have a few. Will also make it easier to clean around as you dont have a hidey-hole at the back for dust / mess to gather... and they're more modern looking. Re: Toilet waste too close to wall. Help! 8Jun 05, 2013 11:34 am Thank you for that. This one from Marbletrend has a adjustable S trap 70-170mm so would be ideal. Problem solved. http://www.marbletrend.com.au/products/ ... ilet-suite Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2658 Looking at some of the designs on websites, they are all selling very similar products. I get that you want something stylish. It's worth looking for search terms like SaveH2O… 2 7010 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4715 |
