Browse Forums Bathrooms and Laundry 1 May 21, 2013 12:23 pm hi ,new to posting .we just had our bathroom renovated and installed a wall hung vanity,well supposed to be wall hung.i rang the builder as i wanted to speak to the plumber as there are visible pipes coming up from the floor and they are ugly.this takes the entire bathroom concept idea that i had away.the builder stated that i cant have the pipes inside the wall due to a beam or something and have opted to go through the floor without consenting me first,can this be fixed as whats the point of a wall hung vanity with pipes showing,he said he could cover them with stainless steel but that doesnt really help? Anyone have ideas? Thanks Re: wall hung vanity with exposed pipes 2May 21, 2013 12:34 pm Is it a stud wall or a brick wall? There could be a support beam behind the vanity but I doubt it. If its all tiled and finished there isn't much you can do now. Did he mentioned this to you before doing it? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: wall hung vanity with exposed pipes 3May 21, 2013 2:24 pm it backs onto a bedroom wall,and pipes come through a brick wall outside.He never said a word to me,he thinks he mentioned it to my husband,but he cant recall it either.it looks ugly,can u recommend an idea to dress it up if i cant change it? we had it wall hung because the toilet is wall hung too,overall it looks good except for the pipes. thanks Re: wall hung vanity with exposed pipes 4May 21, 2013 3:07 pm vangar5 it backs onto a bedroom wall,and pipes come through a brick wall outside.He never said a word to me,he thinks he mentioned it to my husband,but he cant recall it either.it looks ugly,can u recommend an idea to dress it up if i cant change it? we had it wall hung because the toilet is wall hung too,overall it looks good except for the pipes. thanks 2 options is either make a small plinth around the pipe work in the same colour as the vanity or to do the same but tile it. Re: wall hung vanity with exposed pipes 6May 21, 2013 5:28 pm Your best bet is to make a narrow tiled kickboard set in 100mm from either end of the vanity and the depth of the pipes. Tile it in that same as your wall tiles and it should blend in. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: wall hung vanity with exposed pipes 8May 23, 2013 3:58 pm To all who replied to my problem, many thanks.The builder has returned at my request and replaced the plastic pipes with chrome pipes.they look a lot better and smarter,they are still slightly uneven,but i will have to live with that.behind the vanity would have been ideal,but he says there is a supporting beam there and he cant drill through it.would have been nice to know in the beginning. thanks again everyone. Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10907 4 5105 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 |
