Browse Forums Bathrooms and Laundry 1 May 12, 2013 1:09 pm Hi, we currently have x2 showers in our House which are 900x900. In our new House we wish to have one standard 900x900 and the one in our Ensuite much bigger, with maybe twin heads. What is the biggest shower base you can get? I don't mind if I have to build 2 walls at each end so Glass is only on one length if that is what needs to be done. We just want a decent sized shower that we can both go in if need be (or we wish! ) Col Re: Shower Bases 2May 12, 2013 2:52 pm Is there any reason you want a shower base?? I personally much prefer a shower with out a base. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Shower Bases 3May 12, 2013 5:45 pm CuttingEdgeKitchens Is there any reason you want a shower base?? I personally much prefer a shower with out a base. We won't be on a Concrete Slab, so probably have to have a shower base?? Or am I wrong? Don't mind having the Shower base but can't see another way unless somelse has a suggestion, bathrooms and showers are not something I have really done before. Col. Re: Shower Bases 4May 12, 2013 9:41 pm DefenderOwner CuttingEdgeKitchens Is there any reason you want a shower base?? I personally much prefer a shower with out a base. We won't be on a Concrete Slab, so probably have to have a shower base?? Or am I wrong? Don't mind having the Shower base but can't see another way unless somelse has a suggestion, bathrooms and showers are not something I have really done before. Col. You're wrong - but in a good way! We are up off the ground and just had the waterproofer in last week who laid down a green waterproof membrane on the yellow tongue floorboards and up the walls where the showers go ready for the tiles to go over. You have whatever you want! ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Shower Bases 5May 13, 2013 7:01 am DefenderOwner [We won't be on a Concrete Slab, so probably have to have a shower base?? Or am I wrong? Don't mind having the Shower base but can't see another way unless somelse has a suggestion, bathrooms and showers are not something I have really done before. Col. I have two bathrooms in my house upstairs. They don't have a concrete slab and also don't have a shower base. Shower bases are not needed and in my opinion can look cheap. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Shower Bases 6May 13, 2013 12:50 pm Our ensuite shower is a walk in shower 900 x 2100 and I don't think we have a base as such. It will be a tiled base and we don't have a concrete slab. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Shower Bases 7May 13, 2013 4:52 pm HomeAngels Our ensuite shower is a walk in shower 900 x 2100 and I don't think we have a base as such. It will be a tiled base and we don't have a concrete slab. 2100 is pretty big! I obviously have to look into how you can do the base of a shower a bit more... Col Re: Shower Bases 8May 13, 2013 5:14 pm DefenderOwner HomeAngels I obviously have to look into how you can do the base of a shower a bit more... Col Its pretty straight forward. They water proof the sub flooring then put a screeding bed on top and then tile on top of that. This way you can have fully frameless shower screens straight to the floor which looks so much better! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Shower Bases 9May 13, 2013 5:56 pm CuttingEdgeKitchens DefenderOwner HomeAngels I obviously have to look into how you can do the base of a shower a bit more... Col Its pretty straight forward. They water proof the sub flooring then put a screeding bed on top and then tile on top of that. This way you can have fully frameless shower screens straight to the floor which looks so much better! This is one of the few regrets I have with our new place. I didn’t have the ensuite’s sub-floor lowered by 30-40mm to accommodate the depth of screed at the door. ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Shower Bases 10May 13, 2013 6:58 pm Our shower is 2100 long but there is a 1000 opening so I suppose the shower section is 1100 x 900. We don't have a door, it's all tiled. You just walk into the shower. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Shower Bases 11May 13, 2013 8:01 pm HomeAngels Our shower is 2100 long but there is a 1000 opening so I suppose the shower section is 1100 x 900. We don't have a door, it's all tiled. You just walk into the shower. yeah, but what is the length of your shower screen..that will tell us how long your shower is. Re: Shower Bases 12May 13, 2013 9:07 pm rs2000 HomeAngels Our shower is 2100 long but there is a 1000 opening so I suppose the shower section is 1100 x 900. We don't have a door, it's all tiled. You just walk into the shower. yeah, but what is the length of your shower screen..that will tell us how long your shower is. I don't have a shower screen, it's a tiled walk in shower. Here's a pic. In total it measures 2100 x 900 with a 1000 opening. That means section of wall that runs between the shower and basins is 1100. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Shower Bases 14May 14, 2013 7:51 pm Mould shouldn't be a problem if you clean regularly. IMO - definitely avoid a tray if possible! I agree that they just look cheap. Try and make a 'walk in' shower, no glass. That's what we have and I love it, feels so luxurious at home! 1st build: viewtopic.php?f=31&t=59376 *New*-2nd build: viewtopic.php?f=31&t=70324&p=1154282#p1154282 Re: Shower Bases 15May 14, 2013 8:52 pm We won't have a mould problem as I'm going to have our grout colour sealed. Our current shower grout is colour sealed and it keeps it looking new. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Shower Bases 16May 24, 2013 1:59 pm We had quite an argument with the builder over "hobs". We hate them. Again - the less edges the better IMO in a shower. We got our way and have flat surfaces - awesome. As you age you appreciate no steps etc. Surely hobs are things of the past ! Re: Shower Bases 17May 24, 2013 2:24 pm Home angels I love your set up. I would love having no glass to clean. Does very much water escape without a screen? This is going to be a must in my next build. At the moment we have a large walk in shower with just a sheet of glass. It's pretty easy to keep clean. Re: Shower Bases 18May 24, 2013 7:55 pm Brendo Home angels I love your set up. I would love having no glass to clean. Does very much water escape without a screen? This is going to be a must in my next build. At the moment we have a large walk in shower with just a sheet of glass. It's pretty easy to keep clean. No idea re water escape as our house isn't built yet. Fingers crossed I'll be able to answer your question by Christmas time I don't thin it will be an issue. The wall is 1100mm long and even if water splashes back a bit there shouldn't be any problems as it will all be tiled. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9570 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5853 Ask yourself if the insurance company will be aware of the Reno. 4 7385 |
