Browse Forums Bathrooms and Laundry 1 May 01, 2013 7:25 am We are about to start renovating our lovely 80's bathroom, can anyone give advice on layout ideas? We would like a separate bath and shower rather than the existing shower over bath and try and keep the existing drains in the slab if possible, if we have to move them so be it. The room size will be 2800mm X 2400mm Now, Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Planned, Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Need help with bathroom 4May 01, 2013 10:04 am The finished toilet space between the vanity and wall should be at least 800mm and the shower should be 900 x 900mm minimum preferably 1000 x 1000mm. Also don't forget that standard baths usually only come in 1525 and 1675mm lengths so work your shower space around that ( unless you are going for a non-standard type in which case buy the bath then build the shower wall accordingly ). Stewie Re: Need help with bathroom 5May 01, 2013 10:17 am Stewie D The finished toilet space between the vanity and wall should be at least 800mm and the shower should be 900 x 900mm minimum preferably 1000 x 1000mm. Stewie Cheers stewie, the toilet should be fine, it's mainly the shower and bath combo, personally i don't care about the bath but the mrs insists we have it mainly for re-sale. Re: Need help with bathroom 6May 01, 2013 10:37 am Two options. First, this keeps your WC where it is and makes use of the existing waste points. (900x900 shower base, 1750x800 free standing bath, 900w vanity with 2/3 depth cupboard unit, towel rail shown on the sth wall) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Second one is a bit more radical, it requires a shift of the window, and WC but gets it out of view from the doorway. (1000x1000 shower base, 1750x800 free standing bath, 900w vanity with 2/3 depth cupboard unit, towel rail shown on the sth wall) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Need help with bathroom 7May 01, 2013 11:45 am Cheers PAB, I really like the first plan as we wont need to cut into the cupboard, it's got me thinking! Unfortunately the toilet will need to stay where it is due to the expense to move it. Thanks for your input. Re: Need help with bathroom 8May 03, 2013 9:55 pm Just keep in mind that the minimum size for a shower waste is 50mm. The existing vanity and bath are likely to be 40mm pipes. No matter what you do you will have to cut the slab. Firstly to add another drain, then to upgrade the other Re: Need help with bathroom 9May 05, 2013 8:07 pm 33amc Just keep in mind that the minimum size for a shower waste is 50mm. The existing vanity and bath are likely to be 40mm pipes. No matter what you do you will have to cut the slab. Firstly to add another drain, then to upgrade the other Cheers, we have our plumber coming around this week to work out our options.. Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10379 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8231 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11258 |
