Browse Forums Bathrooms and Laundry 1 Apr 14, 2013 7:26 pm Hi, We ahve dark blue small square tiles on our bathroom floor. Grout is old and revolting, can't really get it clean anymore. What's more it's dark grey and looks dirty even when it's clean. I'd love a floor that had no grouted areas to clean, so either tiles that have grout but then the whole surface has been sealed in some way, OR polished concrete. I'm presuming getting polished concrete means a step up into the room? At the moment it goes from laminate boards to the blue tiles with a laminate kind of strip that covers the join. But I presume if I have someone pour concrete it goes over the top or am I wrong and they have to pull up all the floor tiles, then concrete. If so, I'm presuming this is all very expensive. Floor space is only about 2mx2m. Also, where to get quotes in Perth? Thanks. Re: Is it expensive to get poured concrete on bathrm floor? 3Apr 14, 2013 10:32 pm ..and remove the concrete and replace with a concrete mix & stone colour that you want.. $ 3k aprox to: remove, reinstate and grind/polish so long as all things being equal and the site doesn't have any problems based on the 2x2mtrs sq Where you are coming from is where you are going to... Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 11500 Has anyone had experience with using this surfacing? I have read it can stain easily. 0 1361 |
