Browse Forums Bathrooms and Laundry 1 Mar 29, 2013 9:51 pm For my new build I am thinking of going with a fully-frameless (doorless) shower screen for ensuite and bathroom. I like the idea of an easy to clean shower, however I am worried about the overspray etc and the possibility of the bathroom floors getting saturated. What dimensions would you recommend for the floor area of the shower? What length should the screen be to avoid too much overspray? Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Size of shower space for fully-frameless (doorless) show 2Mar 30, 2013 7:02 am Do you mean you want a glass shower panel? Or do you mean a tiled walk-I'm shower? We are just starting our build and we are having a tiled walk-in shower. We chose this for ease of cleaning ie. I will get the grout colour sealed and we are using sealed tiles. The floor measures 900x2100. There is a 1000mm side entrance so I suppose the actual shower bit is 900x1100. It's a bit hard to explain.... Have a look at the plans in my thread or blog. I'm not concerned about water splashing into the bathroom as the walls go to the ceiling. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Size of shower space for fully-frameless (doorless) show 3Mar 30, 2013 7:29 am We also have a tiled walk in shower in the ensuite, I wanted the wall to be about 1500mm high but hubby and the builder talked me into 1700mm high to stop the splashing when washing my hair etc. Re: Size of shower space for fully-frameless (doorless) show 4Mar 30, 2013 8:16 am Our doorless showers are 1000x1100 but are at the end of the room to create a wet area. The spray comes out about 1600mm off the wall but its only light at that point. I really depends on your room size and how you design the layout. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Size of shower space for fully-frameless (doorless) show 5Mar 31, 2013 12:01 am Im pondering this at the moment - online 3D software helps! I have a master ensuite with 1800m bath, double vanity, double shower & W.C. Ive made the shower area completely hobless & glass-less.....the vanity is 2.5 meters away - so that should be more than enough room to protect it and still give (hopefully) amazing big wide open shower space.... Building with 101 Residential in Falcon. Re: Size of shower space for fully-frameless (doorless) show 6Mar 31, 2013 12:07 am You should be able to see my layout here... Building with 101 Residential in Falcon. Re: Size of shower space for fully-frameless (doorless) show 7Mar 31, 2013 8:44 am HomeAngels Do you mean you want a glass shower panel? Or do you mean a tiled walk-I'm shower? I just mean a glass shower panel. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Size of shower space for fully-frameless (doorless) show 8Mar 31, 2013 8:50 am CuttingEdgeKitchens Our doorless showers are 1000x1100 but are at the end of the room to create a wet area. The spray comes out about 1600mm off the wall but its only light at that point. I really depends on your room size and how you design the layout. So 1600mm is probably the minimum to aim for, otherwise I should consider a door. Fortunately it is at the point where I can make adjustments to the room layout although should make a decision soon. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Size of shower space for fully-frameless (doorless) show 9Mar 31, 2013 8:55 am Ours in the house we just moved into is 1x1.7. It's perfect! We only have 3/4 walls, as my parents' have walls to the ceiling but no light gets in, so it's too dark. We have glass above the wall to stop any splashback. I think the door space is 850. I love it! 1st build: viewtopic.php?f=31&t=59376 *New*-2nd build: viewtopic.php?f=31&t=70324&p=1154282#p1154282 Re: Size of shower space for fully-frameless (doorless) show 10Mar 31, 2013 10:11 am Hi Maximus Ours glass panel is 1.5 long and 2.1 high. The opening gap to walk through is 1m. We find this works really well for us. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ 2 4475 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9943 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3576 |
