Browse Forums Bathrooms and Laundry 1 Mar 29, 2013 8:07 pm i am wanting to renovate my bathroom and would like to upgrade the bathtub to an air bath. unfortunately due to size limitations it would have to be a petite one no more than 1400, preferably even 1300. [and this is for a rectangle tub not a corner one]. i can find a bath as tiny as 1220mm, have found a spa at 1400mm but no air baths, smallest airbath i have found so far is 1500mm [Lanark]. does anyone know of one, or does anyone know if there are companies that will retrofit this system to an existing bathtub? if i can't get one then i need to rethink the whole bath idea. also when do the companies do a new catalogue release of their baths as in new styles etc? if it's soon'ish then i can wait and see if something comes out in next release. thanks for any input. nb: i want an airbath over a spa as it has positives like a more gentle massage than jets, lower and even hidden jets, less water usage and possibly [depending on what site you read] more hygienic than a spa bath. if anyone has general input against my reasoning here i would be intrigued to hear that to. Re: a small airbath - possible to find one? 2Mar 30, 2013 7:52 pm i found a small'ish one on Reece website - Mizu at 1400mm http://www.reece.com.au/bathrooms/produ ... air-system it looks very square though with no contours. so not sure this would be very comfortable though [will need to see one to see for sure] so noone else has any input? Re: a small airbath - possible to find one? 3May 02, 2013 7:49 am snowcherry i am wanting to renovate my bathroom and would like to upgrade the bathtub to an air bath. unfortunately due to size limitations it would have to be a petite one no more than 1400, preferably even 1300. [and this is for a rectangle tub not a corner one]. i can find a bath as tiny as 1220mm, have found a spa at 1400mm but no air baths, smallest airbath i have found so far is 1500mm [Lanark]. does anyone know of one, or does anyone know if there are companies that will retrofit this system to an existing bathtub? if i can't get one then i need to rethink the whole bath idea. also when do the companies do a new catalogue release of their baths as in new styles etc? if it's soon'ish then i can wait and see if something comes out in next release. thanks for any input. nb: i want an airbath over a spa as it has positives like a more gentle massage than jets, lower and even hidden jets, less water usage and possibly [depending on what site you read] more hygienic than a spa bath. if anyone has general input against my reasoning here i would be intrigued to hear that to. hello jim from roundbathcompany here we have plenty of bath/spa sizes to suit your needs 1=airbaths are not necessarily hygienic=the airjets are on the base of the bath=they may retain water=cant drain our spas are built to exacting standards all hardplumbed=not hoses all pipework drains to our exclusive lowpoints pipework sanitiser installed=flushout your pipework all jetting is professionally targeted to suit your needs Re: a small airbath - possible to find one? 4May 03, 2013 5:37 pm hi jim, i will check out your company, thank you yes it is possible but watch for noise transmission, decouple as best you can. Maybe wider top and bottom plates with 70mm studs to allow the cabinet to be recessed fully 1 6636 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36960 0 9809 |
