Browse Forums Bathrooms and Laundry 1 Mar 07, 2013 3:50 pm We are on tank water and I dislike the waste of water waiting for the hot water to come through. Currently we put a bucket under the shower but in our new house I would like to do something less unwieldy. Has anyone installed one of the water diverters intended to fix this problem? Is it successful? Thank you Re: Cold water diverter 2Mar 27, 2013 9:56 am I haven't done this myself but have seen a system where you key in a desired water temperature and the shower automatically delivers that. I understand it's efficient, but costly ($800?). Have you looked at this? I can find out details if you're interested? Re: Cold water diverter 3Mar 27, 2013 11:45 am It wouldn't be hard to do for any decent plumber. Getting the right hardware so that the diverter and second waste line looks good will be the hard part. Maybe a local plumbing outlet like Reece would be worth visiting. Uncle Arfur who is a semi-retired plumber and frequents these forums may be able to help. Stewie Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12647 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2588 18 90425 |
