Browse Forums Bathrooms and Laundry 1 Feb 27, 2013 1:17 pm I am reno'ing a bathroom and have cut a 600mm long slot in the slab to get access to old drain from new. Question is do i need to termite proof this slot with termimesh or some other product. I plan to waterproof floor and walls with a paint on membrane. Thanks in advance for advise, Cheers, Andy Re: Termite proof cut in slab to move drain 2Feb 27, 2013 2:16 pm You should, and 75mm of Granitgard should do it, I think you can purchase a bag directly. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Termite proof cut in slab to move drain 4Feb 28, 2013 8:04 am Unless it is a trafficable area you won't need cement over. Cheers Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Termite proof cut in slab to move drain 6Feb 28, 2013 1:12 pm You need to waterproof bathroom walls above bath and the side, there is no point waterproofing under your waste, if the water is getting there then your primary waterproofing has already failed. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Termite proof cut in slab to move drain 7Apr 13, 2013 11:02 am If you intend to walk on the tiles that cover the area where the new waste was cut in, then you need to have a solid substrate. I've pm'd you. Where you are coming from is where you are going to... Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 16672 Hi We have a road close to our place and only an old flimsy wooden fence between us and the Neighbour closest to the road. Any ideas on a sound proof modular fence. Like… 0 5674 Hi all Am new to this forum. I want to get some ideas/info about how to manage an 80 year old factory restoration to convert to a residence. The factory floor is concrete… 0 3412 |
