Hello,
About to sign off on plans but have noticed a problem in the ensuite...
We are using caroma Leda vasque inset basins and phoenix vivid wall set spout/mixer on a backing plate.
http://www.caroma.com.au/bathrooms/basi ... nity-basin
http://www.phoenixtapware.com.au/module ... _BASIN_SET
There is only 200mm between the bench top and the mirror...the basin sits 75mm above the bench top.
Does this seem practical or are they too close? Any suggestions on a solution? We couldn't use a spout that came out from the bench top as it is laminate and we were worried about leaks so the wall was the only option with the basin.
Any help much appreciated!
