Browse Forums Bathrooms and Laundry 1 Feb 11, 2013 2:48 pm Hi helpful members, I'm about to project manage my bathroom renovation and I'm trying to schedule the tradesman in so the bathroom is out of action for as little time as possible. The waterproofing being used is the paint on type, but I don't know how long in need for it to dry before the tiles or screed can be laid over the top. I'm sure that the longer the better, but does anyone who uses this type of waterproofing regularly know the minimum it must be left for to dry. Thanks for your responses. Re: Bathroom reno schedule - How long for waterprrofing to d 2Feb 16, 2013 7:11 am That depends on the waterproofing compound used. We used to use four coats- sometimes more, of Durabit and allow a days drying between each coat at least but that depends on the weather a lot too. Cool, humid conditions means it'll take longer to dry. It is something you definitely don't want to rush. Stewie Re: Bathroom reno schedule - How long for waterprrofing to d 3Feb 16, 2013 11:37 am Some products have a maximum intercoat time meaning you need to do subsequent coatings within a maximum time limit... also depending on temp.. most products have a cure rate based on a mean average temp of 20c, 5 degrees less and you double the cure time, 5 degrees more and you halve the time. my 2cents Where you are coming from is where you are going to... It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 8999 DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 2130 Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10371 |
