Browse Forums Bathrooms and Laundry 1 Feb 09, 2013 11:52 pm We're building a house with no shower downstairs. Wondering what is needed to easily be able to add a shower to the powder/laundry room later down the track. Re: 'Future proofing' shower downstairs 2Feb 10, 2013 7:24 am I would assume you'd need the plumbing there. I can't think of anything else. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: 'Future proofing' shower downstairs 3Feb 10, 2013 9:00 am I am not a builder so this may be a silly idea - but perhaps waterproof the area where the shower would go before you tile the floor space. this will mean you don't have to rip up the tiles and may save labour and material costs later - and trying to have to match tiles later on when needing to replace them after. You can leave the floor as it is then and just add a screen later - unless of course you will be doing a full conversion and removing cupboards etc anyway where the shower will be going as you'll just do it later then. Also if you're tiling your walls now - waterproof before hand. If you're just gyprocking now, then you can waterproof later I guess before you tile the walls in the shower space. AS Home Angels said, I would also think the plumbing and just have the waste there. You don't want to have to try dig your slab up later to get the plumbing right. Blog: http://cbcbuild.blogspot.com.au/ Building Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=62155 Re: 'Future proofing' shower downstairs 4Feb 11, 2013 10:38 am Quote: I am not a builder so this may be a silly idea No it's not Lilac. All the points you raise are pertinent. The only one I would add is to use villaboard for the wall sheeting or at least wet area plasterboard and to also allow or install a fan for ventilation. Stewie Re: 'Future proofing' shower downstairs 5Feb 11, 2013 12:40 pm Ask the builder to quote for capped hot/cold water and waste pipes to the relevant location. As said, see if you can get waterproofing done also. But then again... what timeframe are you talking about? 1 year? 5 years? 15 years? The longer the time until you plan to do it, the more likely you may rethink something in the meantime. Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20665 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16291 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7487 |
