Browse Forums Bathrooms and Laundry 1 Feb 05, 2013 10:35 am Hi, was hoping for a little guidance here. Tried to read through most of the posts but can't find my situation. I have a bathroom extension that's elevated about 4' off the ground. The floor needs replacing. My question is, with it being so high off the ground, what's the strongest material and process that I can put down? Do I need to have an underlying villaboard (?) with cement sheeting ontop to give strength? Sorry, only just starting this journey in renovating and don't know the lingo and we don't have many tradies out in this neck of the woods Re: Elevated Bathroom floor. 2Feb 09, 2013 7:14 pm Hi http://scyon.com.au/ scyon is a rely good material to use if your situation. The board is waterproof and is rely good for suspended works. p.s even though it is waterproof Australian standards state that you still need to waterproof it. Hope this helps As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 540 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8414 |
