Browse Forums Bathrooms and Laundry Re: Help with bathroom layout 3Feb 02, 2013 8:34 am Today is under construction. Thank you for understanding. Re: Help with bathroom layout 5Feb 06, 2013 9:07 am Today is under construction. Thank you for understanding. Re: Help with bathroom layout 6Feb 07, 2013 12:31 pm For the ensuite bathroom I would move the shower to a full length along the wall where you current vanity is. You should still have room for a double vanity along the towel rail wall. From the look of your plan you would need to move the door over to fit a full width shower in though. For the other bathroom are you having a free standing tub or a built-in tub? If you're going with a standard built-in, I would consider having the hob built to fit both walls at either end. You could extend the vanity bench over that end of the bathtub if you liked, and run the mirror the full length of the wall. I would definately try to extend the hob to the toilet wall as well though - otherwise it will just be a wasted space that will collect dust. At least with a large hob you can use it to put bath products or even some glass jars for decoration or something similar. Anna Ethos Interiors is a fresh and creative design firm, specialising in online interior design services for clients all over the world. http://www.ethosinteriors.com.au Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8417 You never have a fridge against wall as you’ve drawn. The doors can’t open past 90 degrees and it’s difficult and maybe impossible to remove drawers 2 15600 Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6139 |
