Browse Forums Bathrooms and Laundry 1 Jan 30, 2013 6:25 pm Hi,
I had inspection today and Tiler was doing the wet areas. I was amazed to see the tile around the drain hole (see the picture). Instead of making the hole in tile, he cut the tile and used pieces but Tiler said this is the way how it should be and would be better looking after the grout. Is it normal? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Bathroom tiling 4Jan 30, 2013 11:55 pm JB1 He didn't break it but cut it to create a fall so water will flow into the drain. Looks ok to me. if it is cut for water flow then it is good. In my wet areas, some of the water does not flow into the drain and stays near walls. Re: Bathroom tiling 8Jan 31, 2013 6:38 am He has done it correctly. Without cutting the tile like that the water wouldnt flow to the drain properly! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 7443 Hi, I'm clearing the tiles from our horrid 50 year old bathroom and preparing to lay new ones. Bugger of a job getting the old… 0 8076 4 14399 |
