Browse Forums Bathrooms and Laundry 1 Apr 09, 2008 7:26 pm firstly thanks for having me, great site
my question is we are renovating our bathroom, and our new vanity is situated about 1meter from our old one. currently there is a hot and a cold male threaded connectors where the taps were screwed in. Now we are going to install mixers, and I want to know if it can be done that insted of getting a plumber out to add 1 mt to the copper piping, can we just tape the thread and install 1mtr flexible pipes through the wall and uto the new vanit mixer? look forward to replys and thanks in advance Grant Re: Flexible water pipes HELP please 2Apr 09, 2008 7:32 pm Welcome to the forum!
Leaving that question for those that know better than me. Sounds tricky. Good luck with answers. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Flexible water pipes HELP please 4Apr 10, 2008 7:56 am I wouldn't be taping the connection... The flexible braided hoses are not meant to be taped... Check the inside, there is a washer which is the seal. By taping the connection you are chancing that some tape may bridge across the rubber seal...
I'd pay a little bit of money and get a plumber to do it riight... Nothing would be worse than a leaking joint in a wall!! Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10831 4 5121 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5730 |
