Browse Forums Bathrooms and Laundry Re: Odd Toilet Vent 4Dec 08, 2012 8:25 am Ive seen these toilets before. They are used to comply to codes where the vent must be within certain distances from the fixture. It may have been easier to vent this way than tie into a 3inch wet vent in the wall, but it is ugly. I saw them used in a campsite with about 5 toilets all vented with side side vents and a studa vent used in each one. If you used a standard toilet you may have problems such a siphoning or gurgling from the water in the trap when another fixture is draining, or it maybe fine! These codes can vary so much that sometimes things are over vented just because one code says it needs it and another says its fine. Or the plumber just put it in because he thought he should! How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 4025 Looking at some of the designs on websites, they are all selling very similar products. I get that you want something stylish. It's worth looking for search terms like SaveH2O… 2 4598 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 3000 |
