Browse Forums Bathrooms and Laundry 1 Nov 27, 2012 9:55 pm I'm in the midst of planning my new home but one thing that's always bugged me is the water shaving shower heads not letting enough water through. I've seen a couple of houses with those monsoon type showers - anyone know how they compare in water usage compared to normal shower heads and water saving shower heads? Re: Shower heads water usage 2Nov 29, 2012 11:21 am Two things. One, they vary, there's good water saving heads and there's awful water saving heads and if the only one you've ever experienced is an awful one it'd put you right off the idea of water saving heads. I had one once but it wasn't my first so I knew it was just a crap design. Two, the good ones feel different at first, sure, but you get used to them pretty quick and it does not feel like theres not enough water. For water usage comparisons doesn't it say on the packaging whats the flow rate? The monsoon ones would be a monsoon so they'd have to be the worst but by how much I don't know. They sound luxurious but I'm not sure how comfortable and practical they are when you just want to get the job done and there's like a monsoon over your head. I'm sure I've seen people post that they've installed a monsoon with another shower head just so's they'll avoid that and they've got a choice which to use. If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you… 10 12139 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9570 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5850 |
