Browse Forums Bathrooms and Laundry 1 Nov 25, 2012 2:19 pm The grout in my shower recess is cracked and in some places coming out. The shower is not leaking anywhere, I checked. Have considered removing grout myself but now think I should get someone in. So who do I get to do this job for me? Re: Regrout shower recess floor 2Nov 26, 2012 3:17 pm You can re grout yourself but it all depends on how hard the grout is. The problem is what has caused the grout to crack or fall out as it maybe deflection and if that is true then grout will crack or fall out again. The main reason for deflection is that the builder did not use ceramic tile underlay that is if your shower is up stairs? Craig Re: Regrout shower recess floor 3Nov 30, 2012 9:12 pm I was wondering about this too. If there is the new painted-on type waterproofing underneath (I'm old enough to remember when they put in solid trays under the tiles) is there a risk of damaging it when you scrape the old grout out? Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4692 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16567 |
