Browse Forums Bathrooms and Laundry 1 Nov 21, 2012 12:42 pm I am renovating an apartment. We are on the top floor. The builder was supposed to use a Smart tile ( bermuda smart tile) drain in my bathroom and shower. He has instead used chrome drains..... He says because the exisitng pipes were too small for the Smart Tile? Is this true???? Re: Builder says he didnt use Smart Tile because...... 2Nov 21, 2012 5:03 pm I find that hard to believe. Can you measure the pipe yourself? Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Builder says he didnt use Smart Tile because...... 3Nov 21, 2012 11:11 pm CuttingEdgeKitchens I find that hard to believe. Can you measure the pipe yourself? I dont think I can measure the pipe now can I? Becos the chrome drain is already installed? How would I go about doing this.? Re: Builder says he didnt use Smart Tile because...... 4Nov 22, 2012 7:15 am Rayess CuttingEdgeKitchens I find that hard to believe. Can you measure the pipe yourself? I dont think I can measure the pipe now can I? Becos the chrome drain is already installed? How would I go about doing this.? Pull the cover of the drain off and you should be able to see the old pipe. If your fingers are long enough you should be able to feel the lip of the drain pipe and the old pipe. You should be able to work out the approximate size of the old pipe from this. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Builder says he didnt use Smart Tile because...... 8Nov 26, 2012 4:44 pm Rayess B STAR make the pipe bigger if it is to small. Use a reducer I asked the builder to use a reducer. He says that the a reducer cannot be used. pipe still too small. But that is the idea of a reducer, to allow a bigger pipe to fit into a smaller pipe! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Builder says he didnt use Smart Tile because...... 9Dec 18, 2012 8:51 pm The Bermuda Smart Tile appears to be available with a 50mm outlet. I'd be slightly worried if my shower drain pipes were smaller than 50mm. If you have already paid for the Smart Tile you may be due a refund as chrome drains are usually cheaper to buy and install. We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16252 I am planning to get shelly dimmers added to the non-smart switches that control light. It has no affect on the mechanical functioning of the switch and this is wired… 1 1429 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17774 |
