Browse Forums Bathrooms and Laundry Re: Silicon around base of toilet? 2Oct 26, 2012 5:20 pm They normally do then as a bonus they screw it down if they feel like it depending on plumber. Sometimes they cut the screws off and just sit them in. My brother is a plumber for Henley and told me this but silicon will hold toilet down fine without screws http://lindeman28.blogspot.com - Our building blog Re: Silicon around base of toilet? 3Oct 27, 2012 6:49 am Its a very normal practise! The silicone is and should be under the tiolet. It is used to glue it to the ground. Almost all plumbers (except the old ones) use silicone these days. I install all 3 of my tiolets in my house with silicone. Most toilets dont have screws in the base anymore its just the silicone that holds them. If its dont properly the silicone should not come out past the edge of the pan. It should be flush and really only be under it glueing it down. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Silicon around base of toilet? 4Oct 28, 2012 5:56 pm Silicone ? As an old fart, all the plumbers ( old ones that CEK is referring too ) I've used in the past always bedded them in with sand/cement mortar and trowelled it off flush with the base of the toilet for a neat finish. Stewie Re: Silicon around base of toilet? 5Oct 28, 2012 8:57 pm Last 2 houses we have built have only had the toilets siliconed down. No screws at all. Should try and get them off, what an absolute pain. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Silicon around base of toilet? 6Oct 28, 2012 9:57 pm I'm glad that someone brought this up as I've been wondering about this - why they dont have screws in the base in Oz any more?!?! Been overseas recently and a family over there had to have some leaks / repairs done to the toilet and we thought - what a nightmare and a huge downtime and inconveniece with only one WC in the apartment - but no, the guy came, fixed and went in less than 1 hour - all thanks to screwable base!!! And not a trace of any harsh work been done! Wow! My signature is distracting people from my wise posts ... Silicon around base of toilet? 7Oct 29, 2012 1:09 am Silicone is great if you ever get a blockage they just cut the toilet off and go down the pipes from there. We had to have a toilet smashed off as it was cemented down, because someone flushed a nappy down our toilet during a home open. very expensive exercise. When plumber replaced toilet he just siliconed it down, no problems. Building the Riva by Dale Alcock Homes. Follow our progress here: https://forum.homeone.com.au/viewtopic.php?t=57075 Re: Silicon around base of toilet? 8Oct 29, 2012 5:15 am Stewie D Silicone ? As an old fart, all the plumbers ( old ones that CEK is referring too ) I've used in the past always bedded them in with sand/cement mortar and trowelled it off flush with the base of the toilet for a neat finish. Stewie Yep, thats the way it used to be done Stewie! Hasnt been done like that by most plumbers for years! I work on multi million dollar homes on the northern beaches of sydney and maybe 1 in 1000 toilets are cemented down. The rest are siliconed! I fitted all 3 of my tiolets with silicone! It is so easy and does a great job if you know what your doing. Give it a go! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Silicon around base of toilet? 9Oct 30, 2012 6:14 pm CuttingEdgeKitchens Most toilets dont have screws in the base anymore its just the silicone that holds them. Really? Never seen one without screws of some sort. What brand model doesn't have them would love to see. Re: Silicon around base of toilet? 10Oct 31, 2012 1:02 pm Ours had screws there but they weren't functional. They were siliconed in to the holes but not into the floor. They put so much silicone down to stick it there we would have had to smash the bowl to move it! A blog about our renovation http://notmynightmare.blogspot.com.au/ Re: Silicon around base of toilet? 11Oct 31, 2012 9:34 pm Just silicone is fine no screws needed as it damages the water proof I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3041 I have seen poly marble shower bases last in excess of 30 years 1 4502 Looking at some of the designs on websites, they are all selling very similar products. I get that you want something stylish. It's worth looking for search terms like SaveH2O… 2 6989 |
