Browse Forums Bathrooms and Laundry 1 Oct 12, 2012 4:07 pm I have 2 shower doors that scrape the glass panels next to the door when closed.
I adjusted the rectangular shower (side glass panels are in line with the door) fine yesterday. But the other shower has panels that come in on an angle and I cant seem to adjust it. It scrapes only on the lower side. If I give one side more gap it scrapes the ither side. Even if i give boths sides the same gap it will scrape both sides!! Any ideas on what Im doing wrong. It seems like the glass is in a bit compared to the upper part but i dont seem to be able to adjust in and out.... Re: Adjusting frameless shower door 3Oct 12, 2012 7:28 pm It looks straight. Just to be clear - this is one of those doors where its just a clamp on the glass and theres a bit off that which goes into a hole in the top/bottom frame. I took off the whole door and secured the bottom clamp to the door making sure it was straight. I then put the bottom back into the frame and moved the door around to see if I could find a point where both sides wouldnt scrape - couldnt find a point. I tried this quite late last night....might try again later. 2 4498 920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people… 4 1567 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9578 |
