Browse Forums Bathrooms and Laundry 1 Sep 18, 2012 9:54 pm Please help, I have like a five second delay when turning on the hot water until it comes out in the shower (never done this before)? all other hot water taps in house work fine.. the delay has only happened in the last week and seems to be getting longer.. Is it like a leak in a pipe somewhere? Please help.. Re: Hot Water Malfunction *** HELP *** 2Sep 18, 2012 11:22 pm As in turn on the tap and nothing comes out for 5 seconds? Defiantly sounds odd, a leak could explain it if the water runs out between the tap and the shower rose and fills with air, probably best to call a plumber to eye ball the problem! 2 Thankyou! As you can see it will need new structural replacement to hold the door, replastering, painting, new anchor plate. The Torsion bars are bent, The roller… 2 2352 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 3 12019 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20197 |
