Hi all,
Im having trouble removing these taps without causing damage. Im sure there has to be a plumbers trick im not aware of because i know the taps are a popular design. My problem is every time i close/clamp the multi grips onto the cone shaped base
it just slips up to where its more narrow and continues all the way up. I've tried rags, cut up garden hose and rubber to help with grip and prevent damage. nothing seems to work. If the ring at the bottom wasnt separate i could get a grip there as its the only part of the tap that square.
