Browse Forums Bathrooms and Laundry 1 Aug 02, 2012 5:31 pm Currently doing up my laundry, plans are - re-tile with and repaint in more modern colours - home made polished concrete bench - Ikea cupboards with overhead storage space - taking into account new dryer (currently on the boat from the UK) - new rear door to let in more light anyway, tiles are up and i'm wondering if the surface under them is screed or the cement slab, seems to be soft and crumbly in places and rock hard in others. I'm thinking it is screed and was planning on attacking the remaining tile glue with the grinder to clean it up then vacuum etc and put down a selfleveling compound of some sort before replacing a sheet of villaboard, waterproofing and finally re-tiling before installing the cupboards. House is late 80's/early 90's model, brick vernear on 2 level full concrete slab, centre drain in the laundry. so questions are: is that screed or concrete slab? best prep for tiling? have I got it right to self level, waterproof then tile? best self levelling product to use? what surface prep prior to self levelling? What waterproofing would this house have previously in the laundry back in the day when it was built? pics are here http://imageshack.us/g/232/image1vtn.jpg/ thanks Re: Laundry Reno questions 2Aug 03, 2012 5:12 pm It sounds like screed to me. I personally dont like the self level products. My tilers always use a screed no matter what. A screed allows you to get the propper falls and are far easier to work with. Just my 2cents though. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Laundry Reno questions 3Aug 03, 2012 8:29 pm bowser Currently doing up my laundry, plans are - re-tile with and repaint in more modern colours - home made polished concrete bench - Ikea cupboards with overhead storage space - taking into account new dryer (currently on the boat from the UK) - new rear door to let in more light anyway, tiles are up and I'm wondering if the surface under them is screed or the cement slab, seems to be soft and crumbly in places and rock hard in others. I'm thinking it is screed and was planning on attacking the remaining tile glue with the grinder to clean it up then vacuum etc and put down a self leveling compound of some sort before replacing a sheet of villa board, waterproofing and finally re-tiling before installing the cupboards. House is late 80's/early 90's model, brick vernier on 2 level full concrete slab, centre drain in the laundry. so questions are: is that screed or concrete slab?screed then slab the screed is probably 50mm thick at the deepest point then the concrete base would appear...lots of self levers are not for wet areas and worse if you're tiling best prep for tiling? have I got it right to self level, waterproof then tile?dry pack then membrane then tile with a rubber based tile adhesive[ensure the tile adhesive will not contaminate the membrane by chemical attack] best self leveling product to use?cement sand and minimal water enough so you can pack it and it stays firm/ use a short level to 'rule the topping' and check falls with what surface prep prior to self leveling ?minimum topping 20mm What waterproofing would this house have previously in the laundry back in the day when it was built? NIL pics are here http://imageshack.us/g/232/image1vtn.jpg/ thanks Where you are coming from is where you are going to... Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10352 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8729 The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone… 4 17097 |
