Browse Forums Bathrooms and Laundry Re: Bathroom heating options? IXL Tastic the only option? 4Jul 11, 2012 4:49 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Bathroom heating options? IXL Tastic the only option? 11Jul 12, 2012 10:20 am So many options, the 'ixl' is a infra red heater and heats what's in front of it, it won't heat a room, you can get fixed bar type heaters, you can get electric heaters that look like air conditioners (I wouldn't put a air con in though, would be fine in heating, but cooling there would be to much moisture in the air and it would probably leak!) You can also get wall mounted panel convection heaters, ducted heating, hydronic heating (more a whole house thing, boiler, hot water radiators etc) and of course the many kinds of underfloor/slab heating, the simplest is an electric blanket installed under the tiles! I suppose if you made the bathroom huge, you could put in a log fire! Or maybe a gas space heater like a rinnai, but they are meant for much larger spaces! 2 Newbie question for flooring options. We are thinking of changing the flooring for bedrooms and passage area. Last time we looked at flooring options was almost 8years… 0 3722 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14636 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12347 |
