Browse Forums Bathrooms and Laundry 1 Jun 11, 2012 1:21 pm We are planning to renovate our small bathroom and I have come up with a design that I think will work (albeit tight) however most of the builders I have had it say it will fit but that it will be too small. If we are going to renovate, I need to get in a bath and toilet as we have kids and our other toilet is way down the other end of the house. [img][IMG]http://img6.imageshack.us/img6/6240/bathroom.JPG[/img] Uploaded with ImageShack.us[/img] I am trying to keep cost down - the only other thing I am considering is having a cavity sliding door installed instead of having the door open outwards or installing a bi-fold. What are your thoughts? Thanks! Re: Small bathroom renovation - is this possible? 3Jun 12, 2012 6:54 am I think that design works perfectly well. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Small bathroom renovation - is this possible? 4Jun 12, 2012 7:09 am I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10048 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11258 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36964 |
