Browse Forums Bathrooms and Laundry Re: Shower shelving 2Jun 07, 2012 9:09 am For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Shower shelving 3Jun 07, 2012 12:04 pm Built in shower shelves look good. And that concludes the list of positives. You loose 70mm out of your bathroom or the room next to it so you can have a 300x300mm? recess in your shower wall. A total waste of space. They create a potential leak spot, yes they are waterproofed but there are 2 more internal corners in your shower. The most common spot for waterproofing to fail. Just my thoughts. Re: Shower shelving 5Jun 15, 2012 3:59 pm Mgilla; my inbuilt shelf is fitted within the existing wall (between my ensuite and the next room) so I didn't lose any space Anyhoo; to answer the OP's question I've just got a good, old fashioned shower caddy in the bathroom that doesn't have a niche. Think it cost me $8 from kmart and when it looks a bit average I'll just replace it with another Re: Shower shelving 6Jun 15, 2012 6:23 pm mgilla You loose 70mm out of your bathroom or the room next to it so you can have a 300x300mm? recess in your shower wall. A total waste of space. . No you dont loose any space in the bathroom or the room next door! The studs or bricks in a wall are around 90mm thick plus render or gyprock ontop of that. The recessed shower shelves sit in this space and waste to space at all. I do however agree about the waterproofing issue. I fitted a piece of 12mm aluminium angle to my wall before it was tiled. Then siliconed a piece of 10mm glass into it after the tiling. It looks like the glass shelf is floating! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4190 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9551 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5820 |
