Browse Forums Bathrooms and Laundry Re: Apartment above has low P trap 2Jun 04, 2012 4:58 pm Landscape Design & Construction http://cherub.squarespace.com/ Re: Apartment above has low P trap 4Jun 04, 2012 5:28 pm Landscape Design & Construction http://cherub.squarespace.com/ Re: Apartment above has low P trap 6Jun 05, 2012 9:52 am Landscape Design & Construction http://cherub.squarespace.com/ Re: Apartment above has low P trap 7Jun 08, 2012 12:21 am Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Apartment above has low P trap 10Jun 17, 2012 10:31 pm S1m0n chippy If you really want to cut down the water noises from upstairs then use some acoustic pipe lagging around all the PVC while you are replacing the ceiling. It will be more effective than insulation in the ceiling. Something like this: http://www.bradfordinsulation.com.au/Pr ... /Pipe.aspx Thanks, would like also work for the Steel pipework (i.e the common building pipework, see pic marked 'outlet') or is this specific to PVC? The pipe lagging will work with any pipe, and will make a huge difference. As far as the ceiling goes. It's a bit hard to tell from your photo what the layout is but it all comes dn to what you like with ceiling heights. Generally the higher the ceiling the better, if you drop the ceiling height all through, the room may fell a little closed in. But without knowing the layout a bulkhead may not suit either. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you… 10 12136 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20607 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11763 |
