Browse Forums Bathrooms and Laundry Re: Help with choosing an ensuite design 22May 28, 2012 8:22 am Deemaree If you do go with A and shorten the toilet, then I would use all the space between bath & toilet for a larger shower-fully tiled wall against the toilet wall-half glass from the hob of the bath up and pivoting door for shower. Thanks Dee, That is exactly what we are planning if we go with A. gelatiii Can you use a sliding door for the toilet? Yep, I think if we go with the A plan above we will shorten the toilet and will go for a sliding door Re: Help with choosing an ensuite design 23May 28, 2012 1:10 pm We have actually had another option given to us which is pretty similar to some of the others and I think I like it. We would extend the room a little bit and we could fit in our 1700 bath. We would probably need to stick with a 900 shower though. Now its between option A and the new option E. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with choosing an ensuite design 24May 28, 2012 4:34 pm fozzy We have actually had another option given to us which is pretty similar to some of the others and I think I like it. We would extend the room a little bit and we could fit in our 1700 bath. We would probably need to stick with a 900 shower though. Now its between option A and the new option E. Prefer option E Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with choosing an ensuite design 25May 31, 2012 7:01 pm Pete_n_Pet Prefer option E Thanks Pete, It looks like we are going with option E. I was worried about the wasted space with such a huge toilet but it looks like we can lop off the end of toilet and use it for a linen press because the other side of the wall is in the hallway. Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6138 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 |
